What compressor Chad?
18,20 or 25G
It will be laggy, like 4500rpm full boost.
What rear housing size as well? 8 or 10cm2
Im waiting to hear back, but it comes with elbow, dump pipe and braided lines and should bolt straight in.
Edited by DSTROY
  • Replies 14.2k
We got any suspension experts that can tell me what tie rods do? they simmilar to caster rods.
im hoping to be able to move the front wheels forward n back say adjusting the wheel base of the car. dosnt need to move a lot just a inch or so.
Tie rods are on the ends of the steering rack, what your after Dan is Castor/radius these go from the front mounts on the sub frame to the lower control arm. Tie rods will adjust toe in/out and camber slightly.
On another note, a nice big box with Apexi written on it arrived today and a smaller one yesterday with the Turbosmart logo :banana:
??IS ANYONE LOOKING FOR A RENTAL PROPERTY??
We where looking at selling, but now we want to keep it and rent it out again.
heres some details.
2 bedroom unit in St Agnes
Built in wardrobes in both rooms
brand new bathroom
brand new kitchen with stainless cooktop/oven etc etc
instant hot water service
polished floorboards through-out
reverse cycle air conditioning (cold as)
just across the road from centro St Agnes shopping centre, and park, playground etc etc
no maintenance required on the outside, thats what we pay strata a cvnt load every 3 months for.
pass it on if you know anyone, we dont really want to go through an agent anymore.
will be roughly 220pw.
Edited by craig R33
Time for car update :blush:
After getting stuck on a dirt rd in Ashton and then towed to adelaide/loby rd and then towed to the workshop i decided to see how my clutch looked.
I actually manage to get the gearbox and clutch out all by myself :)
After that i decided that since im on holidays till monday i might start taking the motor out.
post-38653-1262690934_thumb.jpg post-38653-1262691009_thumb.jpg post-38653-1262691052_thumb.jpg post-38653-1262691089_thumb.jpg
I manage to do all that by myself from sunday to today :D
Time for car update :)
I actually manage to get the gearbox and clutch out all by myself :D
If you need a hand at all let me know...i don't have work till Friday, off Saturday, on again Sunday.
Edit: Helps if i look at the rest of the photos, nice work getting the engine out...now i know who to bring mine to when its time to do a rebuild :blush:
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
    • I am truly amazed someone on this planet was able to cycle the pump using a scan tool. I've always ghetto cycled them on Nissan 90s shit boxes by slamming the brakes and pulling the handbrake to agitate the rear wheels enough to cause a speed difference
    • I didn't actually try it at the time but a Launch X431 with the appropriate software licenses/upsell will have the ABS bleed function. The Consult II you can still find some old sets of equipment but they're really, really expensive:
    • Well I'll start by saying I'm not an engineer. I am going to go with the KiwiCNC ones.  They are made of 7050 alloy have good fillets and radius.  The material alone is in the order of double the strength and fatigue resistance - Those bolts, once torqued correctly place most of the load at the flat face of the mating surface - the 'stretch' you're talking about through torqueing them up would be far more than the extra stretch 'load' placed on them from a steering input or bump. (in my opinion) so I doubt they would flinch.    - but again "not an engineer".      oh and I don't think stitch welding 7050 is a good idea, likely just weaken the material (from what I read)
