I can just appreciate the design and engineering that goes into something this big. I f**king love
Incase you hadn't seen one before. These things are awesome
http://en.wikipedia.org/wiki/Typhoon_class_submarine
If I had the money I'd buy one of these... but at $88 Million USD I think I'd have to sell the GTR which just aint gonna happen
http://www.ussubmarines.com/submarines/phoenix_1000.php3
-D
  • Replies 14.2k
-D
at $78mil it comes in cheaper than a lot of expensive yachts, fark id go for one of these over a yacht! And you cant dive to 305m below sea level with a yacht
I can just appreciate the design and engineering that goes into something this big. I f**king love watching Nat Geo and Discovery for stuff like that, watched them build one of the worlds biggest oil tankers, and how to build an off-shore oil rig. Fascinating shit.
If you sold your car Krishy, youd get 3-4 nights in the Queens Grill Room. Just over $4000 a night.
whats to say i need to sell my car Damo....what if i can afford 3-4 nights :ninja:
Queen Mary 2 and Titanic are nothing compared to the HMAS R33
f**king LOL on that......very very funny there Jarrad
damn didn't think of that when i ordered new plates :P
New plates ordered
just kidding will prob get them soon :D
-D
Yo dawg! We heard you liked subs!....
not a fan of the locals domar.
http://en.wikipedia.org/wiki/Collins_class_submarine
all those faults sounds like an australian built car :) the damn things run on batterys
lol im sick of subs i see them every day along with having subway for lunch
Edited by Inline 6
all those faults sounds like an australian built car :blink: the damn things run on batterys
so do you have a sub lunch in a sub :)
Contrary to media reports, the collins are actually pretty decent diesel subs. They only run on batteries when submerged ;P
Still, theyre a long way from a boomer like the typhoon or an attack sub like the Los Angeles class... time we went nuclear instead of diesel imho ;P
-D
was pretty sub par, was pissing myself laughing last time i went from the staff member putting on the cheese in a suboptimal fashion. all about the cheese coverage
seawolf class for the win
http://military.discovery.com/technology/v...marines-02.html
Edited by Inline 6
Who needs to dive 305 metres below sea level. There are no bikini clad women down there :)
Just rock up in one of the Sunseeker Predators :)
-D
Owww - I have many first hand experiences of why the collins craps all over the LA.......... but nevermind......
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
