Well, Ive driven the R32 2 nights this week. The first night it got vandalised, and tonight I hit a stupid animal and snapped the drivers side mount on my front bumper, so its sticking out from the guard :blush:
anyway, Wayne, here is my old daily. 1989 Mazda 626.
If you missed the intercooler hiding behind the front bumper, and the 95db exhaust, you'd also miss that it had more power than some of the Skylines on this forum :P . Shoulda kept it, would have made an awesome track hack
  • Replies 14.2k
Well, Ive driven the R32 2 nights this week. The first night it got vandalised, and tonight I hit a stupid animal and snapped the drivers side mount on my front bumper, so its sticking out from the guard :D
If you missed the intercooler hiding behind the front bumper, and the 95db exhaust, you'd also miss that it had more power than some of the Skylines on this forum :) . Shoulda kept it, would have made an awesome track hack
I notice that car has a Black & White Cat.
Sooo glad its friday! bin a busy week! tires are going on tomorrow so wheels will be back on :D
i hear that lewis......we had the network down for the last 2 weeks....been so damn frustrating lol
seems my friday is going extra slow today. Alot of driving, and not enough work. Trying to find a present for my 2yo Niece, organise a car trailer to move the drift car tomorrow, and organise some new private health insurance.
is it beer o'clock yet?
Sooooooooooooo how is everyones Friday?
Crap and Boring...Slow also, hardly any customers, there is only so many times you can walk round the store looking for things to do, luckily we have a PC with a TV Tuner in it, so i am watching the Olympics.
Does anyone know when the Drifting is on? As last week, i swear i saw some on around 4pm, just cant remember which day it was or what channel - Hardly watch TV, mostly download episode off the net.
^ we used to go to the dog and duck for beers straight after work - i still pop in every now and then for a pint. Theyve got a good selection of beers Wouldnt bother hanging there any later than 8pm though
Richmond upstairs Friday after work sessions ftw!
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
