  • Replies 14.2k
anyone know of any cheapish but decent accomodation in melbourne?
probably going over there at the end of the month for gogol bordello and some touristy shit, but ill obviously need a place to stay, any suggestions?
When you going? The f1 is on from the 26th I'll be there around then too.
uni lodge on swanston st is pretty cheap dude
My boot "spring" needs some adjustment as it's not popping up enough when I release it. Can anyone tell me how to do that or help me do it? Thanks.
err that would by the hydraulics that open the boot. you might need new ones, dunno if you can get them regassed.
You mean gas struts Damo ;) , hydraulics are liquid operated or actuated cylinders :thumbsup:
Might not help you or David, being long term chronic sufferers, however it does work for people like Ruby and people who are convalescing or training very hard. Its not like said 'well this little saying here is going to solve all your pain woes lads, yes sir, just repeat that mantra twice a day and you'll be right.'
-D
Sounds like a bunch of wank, but I was able to use meditation techniques years ago when I broke my foot in a tournament in the first round. Proud to say I went on into the finals with the injury. Still hurt, but not as much as not being able to "block it out" for that time. I suffered for it when I returned back to Adelaide. My foot was heavily swollen and black in colour. The only reason I got away with going on for so long was because the doctors on hand for the tournament were SA doctors from Adelaide, so they strapped me up and turned a blind eye. The bottom line is 'pain relief' whether meditation, medication or other treatment is only temporary ... long term pain suffers have limited pain relief.
Also when I broke my shoulder in a bike crash. 2 days after I was out of hospital, I was in the garage pulling my bike apart (with the use of one arm). However, nothing to do with "mokuso" or meditation at the time ... I was just impatient to get back on my bike. :)
Everyone is different in their threshold to pain and natural management of pain. I have a high threshold, but I'm sure I'd go mad enduring pain as long as Tangles has.
i heard smoking weed everyday also helps some cronic pain sufferers
hahaha great find Damo.....damn wish my proposal ended like that
we all know your purposals down pt adelaide end like that after $ are exchanged IN ADVANCE i might add
Who was it on SAU who said they had a mate road tune their Nisstune ECU?
Me. I had Pete from PLMS do a quick road tune of my car once he installed the nistune daughterboard. Was good enough to drive home safely but he was quick to stress that a road tune is no substitute for a proper dyno tune
-D
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
    • I am truly amazed someone on this planet was able to cycle the pump using a scan tool. I've always ghetto cycled them on Nissan 90s shit boxes by slamming the brakes and pulling the handbrake to agitate the rear wheels enough to cause a speed difference
