  • Replies 14.2k
Are you ok Cara? Any updates on your friend?
Sorry to hear about the cars involved but your health and your friend's health are way more important. I hope everything works out ok.
my friend had surgery on his back today not sure what for, and i dont know whats happening but im going to the hospital tomorow to see him
As i have just admitted to being a cheap-ass in The Spotted Thread I am going to post an interesting link, Here, to rebuilding brake calipers - As i am replacing my Pads, Rotors, and going Braided Lines for the Track Day, I may as well renew the calipers too.
I did the caliper seals, makes a load of difference.... 20 yr old calipers vs as new... no contest
-D
I'll stop whoring it up in the spotted thread, that DIY looks good. extremes are good if your good to them lol
Yeah, ATM i am going easy on it as i am "bedding in" the clutch and new flywheel.
Only thing I dont like about mine is it doesnt fully disengage the gearbox when it gets alot of heat into it. As for pedal feel? A few members here have driven my car and they have all said it has a great pedal...
EDIT: If you want to hear something really interesting, give Jim Berry a call and ask him about his opinion of Extreme Clutches...
Definitely not a good thing.
should i set the day aside for the call or?..
well back from Canberra/Sydney had an awesome time
only saw about 5 skylines and about 3 coppers so that's a great ratio
sorry to hear of your accident Cara, hope your mate recovers well
why dont you get the R Vu your looking for a 32
ive had my current Extreme in for about 14 months i think
i know its not a skyline people, but your a pretty switched on bunch of peepz,
does anyone know the stuf pattern size for a rx7 series 4 and what other car rims will fit on here.
I have searched google no results, asked mates they all look at me like im planning on giving the thing a good hiding it deserves. p.s sorry bout bad spelling had a few too many. need to get some stockies or decent type rims, and no i wont be doing burnouts on the road, i got no licence to do that anyway.
He won't get one... hes so worried about it not being the perfect one that he'll never actually find a GT-R aha
perfection only goes so far as your wallet allows
note the aus delivered r32 gtr and the one with less than 10,000km milage being advertised on carsales, but each one was over $40k ($65k for the aus delivered one)
-D
If he wants perfect, he will need to increase his budget substantially...
EDIT: Beaten by Dohmar
i think 13k is worth the risk that it might be a genuine sale fly to Perth have a look @ it buy it and put it on the train for home then spend $1000 change all fluids and get leak down and compression tests done so you know what your dealing with
if it has poor compression drive it easy if its all good smile all the way to the track
EDIT
if i had the abilities to acquire 13k i would snap it up today
I totally agree with both dohmar and heslo, hence why I spent the amount of money on my GT-R that I did. I can see that GT-R being a nugget and chewing a bearing straight away, personally I'd steer clear.
Edited by Weezy
its not too bad, tho you're right about the engine, you'd probably want to rebuild the engine straight away for peace of mind, or just strip the car down as much as possible and use it as a track mule till it breaks
i wouldn't mind a 2nd gtr which I can nick parts off
-D
Edit - Having had a look at the pictures, the engine bay looks like its in pretty decent nick and the interior looks good too (no tell-tale bubble on the dashboard)
If your budget was $25k, then getting this one for $13k and spending $12k on replacement parts would be a fun thing to do
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
