  • Replies 14.2k
woo! got my fog lights! couple fuses, a relay, a switch, and some wiring and itll be good to go. should have my front bar by tomorrow as well. rad.
lol. wired the lights in. piss easy. just need a switch now.
thatd be awesome if you could. cheers.
dave, have u got a blanked spot(s) in your dash like i do
if so, i recommend one of these: in the link its the 63027BL (bottom of the page, left hand column)
http://www.narva.com.au/products/browse/standard
HAPPY 21ST BIRTHDAY
TO MY BEST MATE DION
AND TO DAVE
MWA XXXX
Happy Birthday to the double D's - Dave & Dion.
sorry to hear Kellie
happy birthday DD something for the lol's
Haha Madaz. Thanks alot guys :down:
someone just tried to break into my house,lights on im in the lounge and they cut the screen to my kitchen window i have just had 2 cops here actually really scared and want to vomit
Jeez, sorry to hear Kellie, hope your alright now. It shits me when people try to break into houses when its obvious there are people inside (ie. 2 cars in the driveway). Do they get some kind of kick out of it??
it wasnt long after i spoke to you babe that it happened i wanted to call you or james but i seriously couldnt move when i herd the person cutting the screen on the kitchen window
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
