  • Replies 14.2k
woo! got my fog lights! couple fuses, a relay, a switch, and some wiring and itll be good to go. should have my front bar by tomorrow as well. rad.
lol. wired the lights in. piss easy. just need a switch now.
thatd be awesome if you could. cheers.
dave, have u got a blanked spot(s) in your dash like i do
if so, i recommend one of these: in the link its the 63027BL (bottom of the page, left hand column)
http://www.narva.com.au/products/browse/standard
HAPPY 21ST BIRTHDAY
TO MY BEST MATE DION
AND TO DAVE
MWA XXXX
Happy Birthday to the double D's - Dave & Dion.
sorry to hear Kellie
happy birthday DD something for the lol's
Haha Madaz. Thanks alot guys :down:
someone just tried to break into my house,lights on im in the lounge and they cut the screen to my kitchen window i have just had 2 cops here actually really scared and want to vomit
Jeez, sorry to hear Kellie, hope your alright now. It shits me when people try to break into houses when its obvious there are people inside (ie. 2 cars in the driveway). Do they get some kind of kick out of it??
it wasnt long after i spoke to you babe that it happened i wanted to call you or james but i seriously couldnt move when i herd the person cutting the screen on the kitchen window
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
