  • Replies 14.2k
I need new Tie Rod Ends for my R33, and i need them quick, as my car is booked in for the 10th for new tyres and install of the new Tie Rod Ends, before the Track Day. What are peoples thoughts on this and this
call tom at autopro reynella, he hooked me up with some decent ones with grease fittings for cheaper and within a few hours, i have the tools to split them off the rack and pinion link abe
Should have had a look here first, as I have just ordered a set from Grand Nissan...anyone got spare appendages I can have to pay for them (around $300 for a set, ready for pick up on Wednesday). I am having them fitted on Saturday along with new Tyres, and a Wheel Alignment, Tyres $260 Each, Fitting of Rod Ends & Wheel Alignment $70.
So what IP's is everyone using and what sorta clams they worth a month?? My contract with Vodafone is just about over and i wanna upgrade
If you want all out quota with shit customer service, go TPG. If you dont mind paying a little bit more for quality service, go the Node.
I've got KTS adjustable tie rod ends for an R33 laying around, extra lock etc. Interested?
If you cant have Internode or any other ADSL service at your location like myself; Telstra cable is f**king brilliant - although a little expensive, unless you get a bundled deal including your land line.
but fark me its fast. i wouldnt even bother with ADSL if it were available to me. it would be like going back to dial up!
muahahahaha
* ati balancer
* hks pistons 87mm
* Attkd h-beam rods
* hks step-2 camshaft springs
* greddy cam gear cover
* hks oil pump
* apexi multichecker
* acl race bearings
* grex N1 street special camshafts
$3k
:blink:
should have it on tuesday
then will get tomei gasket kit, hks timing belt, n1 water pump
schweet
cant believe my luck, negotiating all the above for 3g
:worship:
no rush tho, all in good time
heres a quick clip i whipped up of the side pipe and maaaaaad flutterzzzz brooo :worship:
excuse the tinging sound you can sorta hear, thats the cut sunkist can i used to block the rooted wastegate
so it didnt sound like a tractor :blink:
http://s177.photobucket.com/albums/w217/cr...01042010009.flv
i agree so much so
so, just did a roadtrip to bendigo and back yesterday with a mate to pick up a car. not bad for 900 bucks either
N13 SVD Pulsar Vector SSS
http://forum.pulsar.org.au/showthread.php/...ormation-thread
God damn. Over 400 pre-orders for the Nissan Silvia hoodies!
How many of those orders will actually be fulfilled?
BTW whats with SAU? Everytime I post something it takes forever to submit. Is there some new screening process installed that slows everything down?
well boys and girls as it turns out im only 27 and need to have tests for Arthritis in my right wrist i cant belive it it seams 7 years of doing nails has taken its toll
yeh love, Ive had arthritis developing since I was 11.
32 now, knees removed without replacement, 2m tall - takes its toll.
currently on mobility impaired pension. seeing i cant do diddly squat
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
