  • Replies 14.2k
I need new Tie Rod Ends for my R33, and i need them quick, as my car is booked in for the 10th for new tyres and install of the new Tie Rod Ends, before the Track Day. What are peoples thoughts on this and this
call tom at autopro reynella, he hooked me up with some decent ones with grease fittings for cheaper and within a few hours, i have the tools to split them off the rack and pinion link abe
Should have had a look here first, as I have just ordered a set from Grand Nissan...anyone got spare appendages I can have to pay for them (around $300 for a set, ready for pick up on Wednesday). I am having them fitted on Saturday along with new Tyres, and a Wheel Alignment, Tyres $260 Each, Fitting of Rod Ends & Wheel Alignment $70.
So what IP's is everyone using and what sorta clams they worth a month?? My contract with Vodafone is just about over and i wanna upgrade
If you want all out quota with shit customer service, go TPG. If you dont mind paying a little bit more for quality service, go the Node.
I've got KTS adjustable tie rod ends for an R33 laying around, extra lock etc. Interested?
If you cant have Internode or any other ADSL service at your location like myself; Telstra cable is f**king brilliant - although a little expensive, unless you get a bundled deal including your land line.
but fark me its fast. i wouldnt even bother with ADSL if it were available to me. it would be like going back to dial up!
muahahahaha
* ati balancer
* hks pistons 87mm
* Attkd h-beam rods
* hks step-2 camshaft springs
* greddy cam gear cover
* hks oil pump
* apexi multichecker
* acl race bearings
* grex N1 street special camshafts
$3k
:blink:
should have it on tuesday
then will get tomei gasket kit, hks timing belt, n1 water pump
schweet
cant believe my luck, negotiating all the above for 3g
:worship:
no rush tho, all in good time
heres a quick clip i whipped up of the side pipe and maaaaaad flutterzzzz brooo :worship:
excuse the tinging sound you can sorta hear, thats the cut sunkist can i used to block the rooted wastegate
so it didnt sound like a tractor :blink:
http://s177.photobucket.com/albums/w217/cr...01042010009.flv
i agree so much so
so, just did a roadtrip to bendigo and back yesterday with a mate to pick up a car. not bad for 900 bucks either
N13 SVD Pulsar Vector SSS
http://forum.pulsar.org.au/showthread.php/...ormation-thread
God damn. Over 400 pre-orders for the Nissan Silvia hoodies!
How many of those orders will actually be fulfilled?
BTW whats with SAU? Everytime I post something it takes forever to submit. Is there some new screening process installed that slows everything down?
well boys and girls as it turns out im only 27 and need to have tests for Arthritis in my right wrist i cant belive it it seams 7 years of doing nails has taken its toll
yeh love, Ive had arthritis developing since I was 11.
32 now, knees removed without replacement, 2m tall - takes its toll.
currently on mobility impaired pension. seeing i cant do diddly squat
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
