  • Replies 14.2k
RB25 run 9.0:1 static compression standard and have slightly higher compression figures because of that. Of a healthy engine you should be looking for 160-170psi. As long as they are all within 10-12psi it should be fine but with 90 psi you will be down a fair bit on power.
EDIT!!
Here's the figures from my manuals;
1.20 MPa = 12 BAR = 176.4 psi
1BAR = 14.7 psi
Standard: 176.4 psi
Limit : 132.3 psi
Difference between cylinders: 14.7 psi
Edited by D_Stirls
EDIT!!
<snip>
1BAR = 14.7 psi
Standard: 176.4 psi
Limit : 132.3 psi
Ive got between 80 - 92 psi on all 6 lol
need some advise,
the fan that sits onfront of the rad has the mesh around it..
does that need to be connected? mine is running consistanly and is pissing me off..
can i disconnect it?
thats the aircon fan mate, confirming you're talkin about the one thats in front (and by front we'd mean closest to the front of the car) of the radiator?
if so, definitely a/c fan, and its probably still sitting in front of the aircon radiator anyways (have you gone that extensive when the actual radiator was out, and get the other radiator (which tucks in under the rad support panel) out?
i still have all the air con connected.. but i NEVER turn it on...
just in the last week the fan has been on everytime i start the car..
wont turn off so i was wondering if i can unplug it?
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
