nah no shopping list
was thinking either tribal again or the swirls that the 31 has :)
and steve as if u forgot the bacon!!!!!!!!!!!!!!!!!!!!!!!!
that car paint sceme has been used a few times already,a guy in QLD on here has one on his GTT and Phatt Audio Customs in Vic has one similar turned into a JDM Cop Car.
JDM R34 cop car video
try some new graphics Cara, not the swirls or tribal ones , something fresh!! and PM or SMS me sometime homie...lol
  • Replies 14.2k
Just got a couple of quotes back for a standard rb26 bottom end swap.. 7-9k ouch.. :ninja:
Looking at a couple of built long motors in japan the moment.. One's a tomei 2.8, 270 tomei cams, tomei oil pump, N1 water pump etc. in a N1 block. Motor has just under 4000k's on it.. May aswell get it checked out by a shop over there and do it right the first time i spose..
Can't justify spending that kind of money on a standard bottom end..
sucks. :laugh:
rb30? :ninja:
I've considered this.. But weezy gets mad and reckons it's molesting it.. Might throw in a rb30et with a A6 bottom end just to make him rage.. haha
Fitspatrick had a rb26 awd adapter for $450 (don't know if they still do) then there's around $600 in machine work to relocate the oil pick up then drill and re tap the rb30 for bigger head studs and a tensioner..
Thats about as much as i've looked into it so far.
Dayum thats quite cheap...
Bargain if you can get it, tho I hate to think what the shipping fees are for something so heavy
-D
Yeah it's cheap at the moment and shipping is around the $1500 mark from what i saw. I'm keen if it goes for under 9k..
That would be around 11k all up including shipping and taxes.
If it goes for any more it might be a better option to get a nitto 2.7 built here..
Weezy has a point (as a purist lol) as Rb30 bottom ends are awesome for the power gain, but the car loses value when you take the original rb26 out of it, which is the only reason I'm going to stick with the 26 bottom end
-D
No pos RB30 bottom ends should be in a GT-R imo
:ninja:
Dont get me wrong, I'm all for twin cam RB30's in VLT's, GTSTs, etc but not a GT-R... C'mon lol
Think I should of called before I went for a drive, went all the way to MC Doyles Crash Repairs and they were closed... as in like they didnt pay their bills and got shut down. Guess I'll have to take my business elsewhere...
11k shipped for engine worth 5800?
Who's making a couple of grand?
My r34 rb26 motor was under 3k del
Yeah bit too much for shipping. I paid 60,000yen for a pallet (~A$700). If I had more money I would have loaded it up.
And Vu plz don't go to mc doyle unless u don't care about how your car comes out.
They're that bad are they? I've heard good and bad about them, was thinking I'd try them out myself but seeing they're close, ah wells.
What i was meaning to say was i'm prepared to pay 9k maximum for it and that would be around the 11k mark delivered after shipping and taxes.. If it goes for any more than that price i'd be looking into getting a motor built here.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
