  • Replies 14.2k
Nice new Avatar Cara :)
I got my car back today, was the manifold turbo gasket that had blown out, the bolts had stretched a little and exhaust began to escape, if i had tightened them up as soon as i heard it i wouldn't of had to replace the gaskets. So $280 later they are replaced with genuine nissan gaskets, and a bag with what was left of said old gaskets.
wont let me submit the online form ruby.. so ill have to get a copy off damo and fill it in..
Craig had the same problem. Damn online crap :D PM me your details (name, addy, phone etc) and I'll sign you up. Do you have the bank details? I'll PM those to you too if not.
Thats not too bad really. I pulled apart mine on the weekend and found $700 worth of things to replace (on top of what I already had known about), thats parts with me doing the labour. :D
Thats not too bad really. I pulled apart mine on the weekend and found $700 worth of things to replace (on top of what I already had known about), thats parts with me doing the labour. :)
Yeah, i could have saved myself about $200 by doing the work myself...but i wouldn't have trusted my workmanship in doing it. Sure it probably isn't that hard to do, just more time consuming then anything, plus he found the tie rod ends not installed correctly, and also replaced the hose clamps on my power steering to try and stop it from leaking.
just got my detailed tax invoice from garage 7
.........all 3 pages lol
I got a 3 page invoice from Tilbrooks in my little car file. I bet you can imagine how not cheap that was, pretty sure the labour it self came to 4k :)
Money well spent i recon. Car has been pushed very hard at the track many many times and the engine is still going strong, same can not be said for many other Rb26 powered cars.
this is true. ive spent much on labour at my preferred mechanics (see below) because each time i tell em to do something, they do it.
woot
-D
Spot on, 26's are great provided you do things right... the FIRST TIME
thats good to hear chad, would suck a fair bit if you had spent alot of money for things to go wrong all the time....
Matty T who's doing your cage?
Lance quoted me 2200 for a full weld in then a couple of hundred extra to have the cage go through the fire wall to the strut towers which im defiantly doing, so around 2500 for a full weld in, which i thought was cheap :(
Earliest they can do it is July :).
hrm, carl williams bashed to death on the day the media revealed his daughter is getting private school fees paid by vic police
my guess is he ratted someone out in exchange for the cash and the inmates put 2+2 together
ahh fun stuff. who needs reality tv when u have reality to keep u entertained? heh
-D
Looking more likely
http://www.smh.com.au/national/as-the-rumo...tml?autostart=1
"Police will investigate if one of those rumours - that Williams had abandoned the code of silence and become a police informer - was the reason he was fatally bashed yesterday inside the maximum security Barwon Prison." and
"Rumours have been circulating in the underworld for nearly 12 months Williams was trying to cut a deal where he would give evidence in major cases in return for a substantial reduction in his crushing jail term."
and Cronic you were spot on too, apparently it was a 'friend' who did it....
-D
Ben, the guy was a murdering weasel that got others to do his dirty work for him.
Can't believe the amount of peeps on other forums that are saying RIP, like he's a hero or something.........Mother Theresa didn't get this sort of attention, lol.
Just hope he made his peace with the big fella in the sky before biting the bullett.
do iiiiit. dont make me finish mine before you :(
random question, who's reputable to send rocker covers to for painting?
Paint them yourself Matty, I did my 31 covers 8 years ago with bright red VHT paint and they still look show room fresh.
and if your keen on some airbrushing flames or ? then pm me I might be able to hook you up
just make sure the rocker cover is spotless outside and a light scuff with a scotchbright, the logo if its has one can be removed and polished up or ?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
