ROFL
Thats the exact one Fliggy was after.... They had advertised it for $1000 on some other website (probably was carsales)
I reckon that ebay is a major blunder - they obviously meant $1000
-D
  • Replies 14.2k
8 months till i'll be in Japan :P
Sweet, Im starting to put 1k every month away from now on to go :)
8 Months away :O, my how time goes by. DAMN IT, i really wanted to go too, i seriously doubt I'll be going now since work has cut my hours down to 1-2 days a week :) , sure i love the time off, but i cant do anything fun now :( . Suppose i had better hop on the unemployment bandwagon and start searching for another job :( ...what to do :)
Yeah Shane, Martin and I were chatting about this the other week .... they said you basically need $5k for the 10-14 day trip they are running. Even makes it a bit of a stretch for me since I would need 2 weeks off work (unpaid since I am a contractor), which then effectively costs me $5k on top :(
BUT Nismo, Tomei, HKS, Tokyo Autosalon and every other cool garage under the sun .... drool.
LALALALALALALALALALA!!!! I cant hear you LALALALALALALALA!!!
yeah unfortunately I have to look at it this way as well.
I wanna take the fam to Europe & the States before I do Japan
I had the funds in cash for when they were going to go in January this year, but I spent it on the car so Im out for the next one.
    • I think in the modern era we live in, if I were converting a hydro lifter head to solid, particularly when chasing revs, I'd be seeing what I could do to use shimless buckets. Those of us with Neos usually have this persistent niggling fear of a shim getting spat out and ruining everything. Shim-over is...yucky that way. At least the Tomei kit appears to be conventional, but it would still be nice if they'd decided to go shimless.
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
