  • Replies 14.2k
Cst's Wayne. I can hook u up a set when I'm bak in adelaide. Currently in a club in Sydney :mad:
We'll talk when your back in Adelaide man :P
Go hard! lol
Edited by Weezy
also have the thought that it was done when engine was cold so pistons and stuff still needed to expand etc..
specs:
Fully balanced
Arp main studs
Arp head studs
Acl bearings
Acl 1.2mm head gasket
Ross/acl pistons
Argo rods
Adj cam gears
Gates timing belt
Has a rb20 exhaust cam on the intake to take the vct off
Was built with all new Nissan bolts, gaskets, seals
Once you have different cams and or adjustable gears, comparing compression results to factory will tell you nothing. This is also the same if you fit a different H/Gasket and the pistons will probably be slightly different compression to the factory ones as well. The difference between the cylinders is what you have to look at but a leak down test is what you really need.
You wouldn't want the difference between cylinders to be more than 10 psi but that's probably not to bad for a cold test.
Edited by D_Stirls
yeh i was reading and found the results not to be too bad..
going to go look at the motor and possibly purchase it.. fit my cams, plenum, turbo etc...
and dale i love my eboost...
would never let it go!
Funny:
Bloody lucky:
:blink:
Brass balls for the bloke. I was at eagle on the hill one day back in 2009 and there was a bunch of hecktik biker boys in full leather on their GSXR's etc racing up and down, in 45 degree heat :\ Crazy kents!
I found out what that grinding noise was, in my drivers side wheel arch. The retaining pin for the hand brake shoe had popped off, and got stuck in the drum, where it started to get ground down. Now to source a pin, and spring.
EDIT: about $5 for a pin and spring from Grand Nissan, so I have ordered 4, may as well replace them all while I am at it, should be here tomorrow or the day after from Melbourne.
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
