  • Replies 14.2k
SH!t, just watch a mate i use to play footy with get layed out by sandilands.....
Kyle Sandilands? Kyle couldn't punch his way out a wet paper bag, let alone lay someone out. ;)
No, not that poof, Aaron sandilands, the Fremantle ruckman
Footy player? They're fairies aren't they? You just touch them and they hit the ground holding a limb and crying!
Hey Steve i hear that you have that engine running. Good to hear that it was all good.
Do you have the Engine Lifting Strap? (The one made out of seat belt material). I tried to find it the other day but i think i may have lent it to you?
Edited by D_Stirls
if they were 8s and 9s, perfect offset for a 31 streeter actually
but they're not, so agreed ;)
hence why i said the widths where shit...
8s-9s with more dish would be win..but then the price would be higher id say :P
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
