  • Replies 14.2k
http://www.adelaidenow.com.au/motorcylist-...u-1225879513502
Very, very close to where I had my accident, and the cyclist was travelling in the same direction I was. Makes my stomach churn just thinking about it. RIP to the biker :)
+1
That section of road is rubbish. Had a mate go down probably that same corner too. We had to use a car to remove his bike from being wedged into the guard rail. He was busted up pretty bad, but nothing life threatening.
Does anyone know how to fit a lift kit to a hilux?
I'm sure I could do it myself, but I've never done it before and rather someone who's done it before help out :)
please help so I can fit some 35" tread!!!
suspension lift kye? if so it'll be easy as
spring and shock are normally separate, so its just a case of out with the old in with the new
Anywhere in Adelaide that will service/diagnose some Cusco coilovers that are knocking?
So far I've tried Manta but they didn't want to touch them.
Pillow ball mounts are stuffed....get rid of them.
Rubber mounts are fine for the street and occasional track work (and much quieter)....unless it's a track car, why bother with those things.
best way to remove battery corrosion?
soapy water and a rag?
baking soda and warm water in a small cup , into a paste then spread on corrosion, rinse with fresh water, but DO NOT get into open cells where you fill water
think you meant distilled water weezy ? it goes inside the battery
random car porn
i gotta do my whole boot :D
mix it in a sprayer a lot thinner it should bubble a lot then rinse with cool fresh water then dry,,,, any thick corrosion use a toothbrush or soft scrubber..
have fun...lol
PS it eats clothes slowly so do it with old crappy ones
only cost a few bucks to do it, look in the baking isle for baking soda
have fun...lol
ive got a box of baking soda in the kitchen
just trying to work out what mixture to use as the last time i did it , well failed epicly because corrosion is back again ...
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
