  • Replies 14.2k
Good riddance to a rubbish clutch
To be honest, it hasnt faired too bad. Its done nearly 50k over 4 years.
Exactly how mine looked when i pulled it out, whats going back in its place
Jim Berry carbide plate. Along with my RB25 and R33 S2 box.
How'd you go getting it all out Dion , struggle much or? Good to see some progress :P
Not too bad. I went to a party last night, got home at some un-godly hour, slept a bit and then went out there with some Corona's lol.
pics of new clutch? and how much?
I dont have it yet. Its roughly around $1k. I'm sending him 2 complete aftermarket clutches to use parts from / trade in aswell (included in that price).
sounds a bit gay
how many jigga watts is it rated too
sounds a bit gay
well they are useless to me.... Will cost me $800 for another Xtreme so I might aswell pay $200 more....
he said it will hold 300rwkw and can give it hell - may be able to handle more I dont know, I just said it has to be able to hold that.
why so much?
a NPC i can get for $550 +$30 shipping
will hold 350rwkw and a 1250kg pressure plate but that's ok your the one that needs to be happy with your purchase
Yeah I know, but whatever I do somebody somewhere is always going to say it was the wrong choice. I did consider getting a NPC clutch, and may still do so - nothing is set in concrete yet!
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
