URGENT!!!
Anyone got S2 R33 rear brake pads lying around? Even a used set for the 2 pot calipers ... even one side ... don't care. Need asap.
Started brake upgrade on the Stagea and I'm short a set of pads I thought I had. Stag is my daily, so I need her finished asap ... even with a temp set of pads.
PM me or sms 0449 928 227.
Ruby
  • Replies 14.2k
I had my F**K EXAMS afterparty in town last night. I had many a beverage lol. Woke up in a house at Henley Beach, got home at 2pm today. Basically the first half of today (and some of last night) was the same storyline as Dude Wheres My Car. Now my butt hurts (I had to push my sphincter back in when I woke up this morning), and my fingers smell like peanut butter - WTF??!!
^^^ Fixed for completeness :P
Hey Andrew, you left your top and wheel brace thingy behind today. Don't worry mate, I got them for you! It'll cost you a turbo-manifold gasket ;)
Oh, and I left my 30m ext cord at the yard too :P
Ah cool mate - give me a ring tomorrow and you can pop over and pick up your gasket .... probably won't be home til later in the arvo though - if you want I can leave the gasket in my letterbox?
Bugger - I was going to yell out to you not to forget your cord, but figured you would have to drive PAST it on your way out, so would see it. You might be lucky and it still be there tomorrow.
Thats cool. I can pick it up from your letterbox tomorrow. I'll be home most of the day, but will be shooting out about lunchtime.
Yeah, I was in a bit of a rush to make sure I got Tracy to work on time, that I left in a hurry. :)
Drove past earlier and had a look from the Cavan Road end of the yard, but its obviously been nicked or taken in upon lockup. I'll chase it up first thing tomorrow.
URGENT!!!
Ruby
Ruby i have some brake pads for a R33.....pretty sure the S1 and S2's are the same mate.....they are used but still got a heap of meat left on them mate.....they are lucas pads....you have my number contact me on that mate....btw pm has been sent as well :)
if someone has a stolen i phone and its jail broken can it be tracked?
my brother had his stolen and he jailbroke it...
cheers
Yes, unless you disabled apples backdoor with SBSettings app from Cydia by turning the kill switch off.
URGENT!!!
Ruby
All sorted out now thanks. Thanks to those who offered :)
I can get you some standard struts and I will have wheels with good tread but they're on the car and have nothing else to put on it Kye.
Cheers man. I'll let you know shortly if the ones that I've lined up fall through.
Thanks
One sunny day in January, 2011 an old man approached the Canberra Lodge where he'd been sitting on a park bench. He spoke to Commonwealth security standing guard and said, "I would like to go in and meet with the Prime Minister Kevin Rudd."
The Guard looked at the man and said, "Sir, Mr. Rudd is no longer Prime Minister and no longer resides here."
The old man said, "Okay", and walked away.
The following day, the same man approached the Lodge "I would like to go in and meet with the Prime Minister Kevin Rudd."
The Guard again told the man, "Sir, as I said yesterday, Mr. Kevin Rudd is no longer the Prime Minister and no longer resides here."
The man thanked him and, again, just walked away.
The third day, the same man approached the Lodge and spoke to the very same Guard saying, "I would like to go in and meet with Prime Minister Kevin Rudd"
The Guard, understandably agitated at this point, looked at the man and said, "Sir, this is the third day in a row you have been here asking to speak to Mr. Rudd I’ve told you already that Mr. Rudd is no longer Prime Minister and no longer resides here. Don't you understand?"
The old man looked at the Guard and said, "Oh, I understand. I just love hearing you say it."
The Guard snapped to attention, saluted, and said, "See you tomorrow, Sir."
:( f**king fantastic!
HAHAHAHA :(
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
