  • Replies 14.2k
first day at work with the magistrates court was a sucess :D
good ppl and interesting work... already seen 2 ppl i know rock up to sort out their fees/fines.
had a celebration dinner on sat night with teh mrs. bought 2 300gm cuts of wagyu grade scotch fillet... at $90/Kg it is worth every cent! nothing better than a rare primo quality steak to get me going :cool:
I'm filling out my new contract and came across these thing that i dont know what they are or dont know how to find out where to find them.
SWIFT code
(Compulsory for ALL countries)
IBAN Code
(Compulsory for EU countries)
ABA Code ( for US)
or
BIC (Bank Identification Code)
It's for my pay to go in so I'm just wondering if i need them or not.
cheers
i think i may have just taken somebody's speeding fine.
South road, next to Mitsubishi's, there is a speed camera in the bedding place across the road, in the car park. I see the silver ford wagon, and assume it is a speed camera, so i go from 60, to 55kph, just to be safe. Meanwhile, i notice a car coming up my ass at a decent rate of speed, in the right hand lane.
so i pass through the camera, and it doesnt go off, but this car has flown past me, and the camera has flashed, as he is on my front quarter. Leaving only my numberplate in view.
The camera only flashed once, which i was suprised about. But being quick to think, i grabbed his rego, the make, model, colour, and time of this car, and noted it down on my phone.
Basically, i am waiting for the letter to come, assuming it's me that they think was speeding.
What can/should i do?
I'm on my P Plates, have been driving since i was 17, and am now 20, and have survived on one point for 2.5 years, and i really don't want to lose my licence for somebody elses disregard for speeding.
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
