  • Replies 14.2k
So looking at a new phone and im looking at the HTC legend. Anyone heard anything about them or had use of one?? Don't mention iphone to me cause i can't stand apple stuff, even simple things like itunes is a load of wank....
my X1 is still at the repair centre... has been for 5 weeks... must be pretty fkd lol.
meanwhile, just got a phonecall from manager "you new work car has been ordered"
yew!
Spark Silver 2010 Subaru Forester X on its way :ninja:
went thru 3 myself at work, 100% failure rate over a year... screen looses calibration all the time, and lockup when you go into and out of 3G
Imate =failure
Nokia , I dumped those as well , used to be decent now they suck
Sony, 3 failures from 3 top line models in less then 6 months, Optus then gave me a Iphone 3G Second generation, thought I would hate it , but so far so good. only a few bitches since OS4 on it.
if it wasn't free I wouldnt buy one
Blackberry Storm ftw, free unlimited downloads, but only available through Vodafone.
forgot that one,, are they any better then the old ones ? I have a few in a box, DEAD ..lol
common as mud in USA.
best reason for a Iphone is it runs my car alarm ....the module is being certified for use here now..lol of course the car start feature is disable for ADR rules.. grrrrrr
Viper ad
Viper ad
How easy would it be to hack the app and rob cars with your iPhone?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
