I despise itunes how hard is it to put music onto what is essential an overrated USB drive? My wifes $100 music player is easier to use then anything apple produces
I don't understand how telling ITunes "this is the directory my music is in, now add it all to the library" is hard? I think it is awesome.
And I was more talking about the App Store than ITunes .... anyone over 15 and has a half decent car stereo rarely listens uses their IPhone for music anyhow IMHO.
  • Replies 14.2k
That would be sweet man. Might have to see if matty can drop it down.
Anyone else have trouble writing in the reply box on their iphone? I touch the box to type and it does nothing, use to work fine when i first got the phone
Edited by DSTROY
I dont have any troubles. Maybe try clearing the internet cache? (Settings -> Safari -> Clear Cache)
Fu*k yeh. ARC cooler with hard piping kit just arrived. Has HKS silicon hoses and a greddy intercooler pipe.
Jake like this. Putting the casino winnings to good use i see?
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
