  • Replies 14.2k
Just finished my breakfast .... mmmmm 6 rashers of short back, 4 eggs, salt, pepper and smoky bbq sauce = WIN
you wont fit into your club shirt eating that, next time you get the urge better invite me over :whistling:
Dion and Fabs32 your clutches have been ordered
I'm upgrading the organization to Windows Server 2008 tonight. And Exchange 2007.
All by myself.
Oh god.
It's going to be a late one!
Yeah. Im not a fan of the new way they separated exchange from AD (which tbh is the old ways as thats how it used to be pre-2003)
setup win2008 on a vhost last year and the damn thing needed 4192megs to install. Not a meg less. Was very frustrating. I had to fool the vm by creating a hdd swap. Which made the install go on for a long time due to page swapping. Fun.
-D
I just finished polishing the 35 .... did a full "Meguire's Swirl Remover 2.0" light cut and polish yesterday, then today have done a full-on "Mequire's Tech Wax 2.0" polish and hand buff .... needless to say I am a bit tired and sore now .... but the 35 looks like someone has just poured an icy jug of water all over it .... mmmmm WET LOOK!
-D
Why the f**k did they move back to Exchange 5.5 days again?! That's f**ked.
I had to do a few recoveries for 5.5... oh my god... worst experience in my life. So incredibly difficult.
yeah so now when creating a new user, instead of getting an email account and a home share created automatically now u gotta create the folder, share it, put that in AD and then open up exchange mgmt console and create the mailbox - which does propagate into ad but still, its a pita...
-D
So I need to buy everything to give my RB25 a major service tomorrow. Obviously I know where I could go, and what I need, but does anyone have any advice on cheap places and things to watch out for? The service itself will be done by me - as opposed to a mechanic. Much appreciated :whistling:
Go to Motor Traders, and start from there.
Ryco Filters, Z145a i think is the part number for your oil filter.
Do the Fuel Filter also. Gates Timing belts, maybe replace your thermostat while you are at it.
Gerbox and diff oil, yeah, i guess people have their own preferences.
Just go over everything, feel the swaybar and links, check for cracks in bushes..simple things like that.
Edited by skwiz
The mechanic who is doing it, would know exactly what to do. Labour..maybe 2 hours..ish.
bingo
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
