  • Replies 14.2k
Go to Motor Traders, and start from there.
Ryco Filters, Z145a i think is the part number for your oil filter.
Do the Fuel Filter also. Gates Timing belts, maybe replace your thermostat while you are at it.
Gerbox and diff oil, yeah, i guess people have their own preferences.
Just go over everything, feel the swaybar and links, check for cracks in bushes..simple things like that.
and water pump! since the front of the engines going to be off anyways..
Edited by Import S13
Ooooooooo ARC :whistling:
Yes you can see 2 pipes going into the cooler, One for each turbo :)
1 Gutted door :whistling:
Also been speaking with CAMS today. Got them to send me all the info i need on making my car a Race/Rally car so i can drive it on the street hehe. Straight from the document
A dedicated rally car can only be used on public roads under the following circumstances:
To participate in an official CAMS event.
 To drive the vehicle to and from all aspects of that event.
 To drive the vehicle to and from official promotional events, including media days and displays.
 To drive to and from maintenance/repair establishments. This may include testing and evaluation.
 Any other activities at the request of the SA CAMS office.
Yes im doing some testing to and from Villis on a Friday night haha
Rant,
Coming home from a mates place tonight. Coming onto north east rd from Kelly street. Look left look right twice and go. According to the policeman this wasnt enough and i didnt come to a complete stop at the stop sign. $332 fine and 3 points :whistling:
Unfortunately the vehicle must come to a COMPLETE stop. That means stopping before the line, applying the handbrake for a second (or 2, just to be sure), then treating the intersection as a "give way". Done too many driving tests (military especially) where thats an instant fail.
Anyone know how to find how many demerit points I got let? Or when they dissapear after a few years?
Cheers
They disappear after 3 years of the date of offence
If you've got 6 accrued (half) you'll get a "you're well on your way to losing your licence" letter that will show up what you've gained LOL
Correct, when I was learning to drive, my Instructor said to stop at the line, and wait at least 5 seconds before moving off, of course making sure no traffic is coming the other way.
Do fixed speed/red light camera know which car on which lane the vehicle was speeding?
Today, I was sitting at about 50km/h in a 50 zone driving through an intersection that I knew had a fixed camera then mid-intersection BAM flash in the left side mirror and corner of my eye to the right a car appeared out of nowhere and braked hard... so at the time the car would of been side by side next to me or slightly behind - hope my truck didnt get in the way of the moron's numberplate or the fine getting sent to me instead...
yes they do, theres 2 extra pads in each lane. Even if you did obscure, they wont ping u
how hard could something be to find
i want an intercooler core. 450 x 300 x 75 (would prefer thinner but cant be choosy)
got one with outlets at either end, kinda want them at the same end for simplicity (like this)
however these ones have 3" outlets. bit too big for my application (2" max)
who else sells coolers with odd outlets like that, and reasonably cheap?
Cheers :D
you can get a kit from Kudos Motorsport Dion, but i guess you dont wanna wait for it seeing as your doing it all tomorrow.
Thanks, I did see those but Ive been told not to use the genuine nissan waterpumps, because they are generic to the 20/25/neo and therefore have an elongated hole that leaks... :cool:
go to nissan for timing belts
Been told this too, apparantly gates ones are noisy??
Yeppo :)
Cheers guys :)
does anyone know where the heck i can get some of these style clamps from today?
they are called "constant tension" , "preformed" or spring band clamps"
from my understanding, they are a factory-only style clamp, and are rarely sold aftermarket.
Tridon make them, as do a few other smaller brands.
need some 23 and 25mm ones TODAY, and have already tried the following:
sprints
repco
supercheap
universal fastners
motor traders
pirtek
enzed
CBC
any other suggestions?
    • I think in the modern era we live in, if I were converting a hydro lifter head to solid, particularly when chasing revs, I'd be seeing what I could do to use shimless buckets. Those of us with Neos usually have this persistent niggling fear of a shim getting spat out and ruining everything. Shim-over is...yucky that way. At least the Tomei kit appears to be conventional, but it would still be nice if they'd decided to go shimless.
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
