]']Saw a black R34 GTR on old northern road towards the wisemans area
plates RUFGTR (i think) u on here? nice GTR mate...
i was in the white r32 GTR that looked at ya..as i was on coming..
i also spotted this last night turning onto M2
yummi :wassup:
Spotted : a blue r32 gtr on batt st, South Penrith. Plates MIDN9T.
Also saw a black r33 in the Croydon 7-11 service station a few days back. And a maroon r33 gtst outside Penrith RSL club, 400r front bar, 3 spoke rims, silver mesh in the front bar.
spotted: ECR 33T this morning on windsor rd near baulkham hills....
sam the new rims look awesome.......
werent you going to go wakefield today ?
Spotted Shonen today :D
ThanX mate your's look great too. I was going to go to wakefield but pulled out so I can go to Oran park on Sunday for the UAS track day
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
