up in newcastle for the weekend and spotted 3 lines in/around n00bys.
Green r32 gts-t maybe ???
maroon gts-t series 1.5 my guess lots of stickers nismo + apexi i noticed
gunmetal grey r32 gtr with a big HKS front mount looked very nice
all about 1:45ish
Not me I guess :D
I spotted a black GTR on Newline Road yesterday (on the Boundary Road roundabout). It was coming the other way. I quickly waved, they just stared at me...Guess they didn't see me wave lol :D
wil..
VIS33R on Pittwater rd in narrabeen, warriewood, mona vale etc :) Guess you dont recognise stageas yet!! :) i tried to get your attention but you still failed to notice me, i was driving beside you at one stage.
I saw a Black r34 rego HPI-34T at the Eastwood end of Balaclava Rd.
Had some cute looking chick in the passenger seat... but was driving away so i couldnt really tell.
Anyway, Hi~! to you :D
hmm isnt that the former HPI project 34 ???
heard ben ellis sold it....see it around blacktown every now and again.
Grrrr... one of these days I'll be spotted ;-)
Did > 2000k's, Wed to Sunday, nice little loop ( Bathurst --> Tamworth --> Coffs --> Soldier's Point --> Newy --> Syd Outskirts --> Bathurst ) - Only saw 4 !! Lines
Wed Evening - None (Bth to Tamworth)
Thurs - 1 (Tamworth to Coffs) - SP001A ? Black R32 - parked at annuka
Fri - 2 Black R33 & Bright Yellow R32
Sat - None
Sun - Rather Nice Black R32 coming down towards Newy
I was driving ZebHax (Silver '33)
oh well...... I'll just have to do another small loop soon...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
