up in newcastle for the weekend and spotted 3 lines in/around n00bys.
Green r32 gts-t maybe ???
maroon gts-t series 1.5 my guess lots of stickers nismo + apexi i noticed
gunmetal grey r32 gtr with a big HKS front mount looked very nice
all about 1:45ish
Not me I guess :D
I spotted a black GTR on Newline Road yesterday (on the Boundary Road roundabout). It was coming the other way. I quickly waved, they just stared at me...Guess they didn't see me wave lol :D
wil..
VIS33R on Pittwater rd in narrabeen, warriewood, mona vale etc :) Guess you dont recognise stageas yet!! :) i tried to get your attention but you still failed to notice me, i was driving beside you at one stage.
I saw a Black r34 rego HPI-34T at the Eastwood end of Balaclava Rd.
Had some cute looking chick in the passenger seat... but was driving away so i couldnt really tell.
Anyway, Hi~! to you :D
hmm isnt that the former HPI project 34 ???
heard ben ellis sold it....see it around blacktown every now and again.
Grrrr... one of these days I'll be spotted ;-)
Did > 2000k's, Wed to Sunday, nice little loop ( Bathurst --> Tamworth --> Coffs --> Soldier's Point --> Newy --> Syd Outskirts --> Bathurst ) - Only saw 4 !! Lines
Wed Evening - None (Bth to Tamworth)
Thurs - 1 (Tamworth to Coffs) - SP001A ? Black R32 - parked at annuka
Fri - 2 Black R33 & Bright Yellow R32
Sat - None
Sun - Rather Nice Black R32 coming down towards Newy
I was driving ZebHax (Silver '33)
oh well...... I'll just have to do another small loop soon...
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
