Spotted HPI-34T  Black R34 GTT in epping this morning, stopped at the lights next to Tuffy's Mufflers. Nice FMIC! :rofl:
hmm must have got a new one...cause it orginally had a Apex gt spec one..but then at the drift nats it didnt have one !!!
anyways on wednesday...saw GOZIRA parked outside powerplay....
F*CK I WANT ONE.......and those S tune stickers look really sweet in real life....
hey tosh that price you quoted me...does that include putting them on as well ?
anyways make sure you have a BLACK Vspec II NUR lined up for me in a few years time !!! hehe.... :wassup:
haha that reminds me.....the FIRST R34 GTR i ever saw in real life was a car youll be familar with.....NUR-34R.......this was before i got my skyline....and man....I almost crashed my car cause i couldnt keep my eyes off it.
nah mate application isnt included...
haha so you want a Black NUR Spec??? better make friends with Terry Ashwood then :rofl: oh and cross your fingers he decides to sell it
NUR-34R is the only one in the country
Spotted Friday morning outside Jamison Square on Warringah Road.
HCR-320 with SAU stickers all over it.
black wheels and some guy with blonde spikey hair inside looking hard O_o
actually not really he just had a smile on his face haha
Looked nice whoever it was but needs to be de-winged imo :)
Spotted 2 skylines today.
One was an r33 gtst on York Rd ( south penrith ), black, and it wasnt too loud.
2nd was in Nepean Square, Silver R32 GTST, it had a gold "turbo" badge on the back where GTSt usually is.
i also saw a black S13 Silvia, the reason i mention this is because it had TOMMY KAIRA on the grill thing inbetween the headlights, also had a rear wing that i have never seen before. It had no badges either.
yeh that's Steve.
my mates Cousin.
Genuine Tommy Kaira Bodykit
Spotted BY BY and owner :) at UAS today. Also spotted my car on the UAS dyno :) hehe
Also spotted a white R33 GTR on Gilbert Road today. I waved and flashed, he waved, I forgot to look at the number plates..LOL.
And, I saw a grey R33 GTS-T with lots of passengers boosting past UAS as I was about to turn. I flashed and waved, the driver ignored, but hey, one of the passengers waved! :P
wil..
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
