im still waiting to get it regoed
i was driving to get the blue slip (yeah right) so it was purely legal. ill get it regoed next week
The guy at the Caltex just along from where I 1st saw you seems to have a realistic approach to the pink slip process. :D
Spotted: Funkymonkey looking like a lost tourist in the back streets of chatswood in teh Ceffy after steak dinner last night :D
Also GTS-33R this morning on the highway at Chatswood
I WAS a lost tourist lol... was trying to get to a mate's house in chatswood, and got hopelessly lost. THen I ran into Carlo and then you... wierd.
Also saw a Silver R33 with a CF bonnet, awfully similar to the one at the meet on Parra road around lunchtime on Friday.
pwnd some R33 N/A that insisted on showing off his revving skills at the lights outside fox studios at about 2am last night. "OMGWTFIGOTPWNDBYAMAXIMAHULEH"
hahaha its a wonder you didn't spot the other 17 skylines that left at the same time :D
That areas like my backyard what was going on down there.
I should have checked it out but that road down to avon dam is my private track causing me to speed and slide and hahahaha...... whoops
funny, I think the same urge came over a few of the cars :D
bit narrow down there tho....long way to the bottom at some places....
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
