yesterday
spotted
gunmetal r32 gtst 4 door on M2 round lunch
had gtr bonnet and wheels
almost 100% its the dude on this forum with the gtr plenum on the rb20.
my gf was driving, she was in as a hurry if you noticed
you finally let your gf drive your car?
wow.. she must be the one john...
Omg I saw a fully HAWT skyrine with the number plates BY BY. The driver looked like a total spunk rat! There was a really HAWT white MR2 driving behind it with a hot curly haired guy!
If anyone knows these hotties can you get them to PM me!!
Was he ok? Can you beat him down for me next time you see him?
hahaha... you better believe i will!!!!!! i'll even steal the guys plates for ya! :uh-huh: as for ok... yeah.. he seemed like a nice guy... even said he was on these forums?!?! this was over a year ago though!!! either way.. hes got nothing on you!!! ;)
:) whose 1louis!?!
also spotted a black 34 at strathfield station today.. plates AQR something... :wavey:
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
