unfortunately i just saw a beautiful white R33 GTR being towed off Harbour Bridge... (i went past in a taxi)
Licence plate SEBAZ
A nasty front-bender of an accident - the hood was crinkled, but the front bar damage couldve been worse.....
Saw a beautiful yellow R34 GTR parked in an open car park of an office block benind the McD's on Lane Cove Rd Ryde(?) at 1:30 pm
Also spotted a Silver R33 GTR heading north on Woodville Rd Merrylands ARA *** ?
spotted a silver r32 on marsden rd just then... beeped at him/her!!!  hehe.. it was kinda loud in the quiet night!!  think it might have been you, silv? don't you hvae a silver r32 with a black front bar?!?!
yah it was me, thought it was you.
your the only one to beep like a maniac, would have beeped back but was talking on the mobile.
i saw a yellow r34 with air brushing vf011? @ licombe also a red r34 both with bodykits. saw a gathering of 60+ odd bikes @ concord west.
was there a comp or something @ olympic park? i saw the japan canoe/kayaking ream hanging around out side telstra stadium
Spotted a few r31's in Sutherland last night. Took this photo of one.
Can't believe no one spotted me at all in 2 hours of driving from Cherrybrook to Sutherland and back again.
Also spotted Benty (red r33) at IBM a few weeks ago. Looks very much like SHRUGZ but with a different plate, and wheels.
hey didn't we see you in land cove merli? or was that our other resident purple gtr?
Yah, that was me... That was probably the last time I drove it :cry:
I might take it for a spin tomorrow actually :cheers:
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
