unfortunately i just saw a beautiful white R33 GTR being towed off Harbour Bridge... (i went past in a taxi)
Licence plate SEBAZ
A nasty front-bender of an accident - the hood was crinkled, but the front bar damage couldve been worse.....
Saw a beautiful yellow R34 GTR parked in an open car park of an office block benind the McD's on Lane Cove Rd Ryde(?) at 1:30 pm
Also spotted a Silver R33 GTR heading north on Woodville Rd Merrylands ARA *** ?
spotted a silver r32 on marsden rd just then... beeped at him/her!!!  hehe.. it was kinda loud in the quiet night!!  think it might have been you, silv? don't you hvae a silver r32 with a black front bar?!?!
yah it was me, thought it was you.
your the only one to beep like a maniac, would have beeped back but was talking on the mobile.
i saw a yellow r34 with air brushing vf011? @ licombe also a red r34 both with bodykits. saw a gathering of 60+ odd bikes @ concord west.
was there a comp or something @ olympic park? i saw the japan canoe/kayaking ream hanging around out side telstra stadium
Spotted a few r31's in Sutherland last night. Took this photo of one.
Can't believe no one spotted me at all in 2 hours of driving from Cherrybrook to Sutherland and back again.
Also spotted Benty (red r33) at IBM a few weeks ago. Looks very much like SHRUGZ but with a different plate, and wheels.
hey didn't we see you in land cove merli? or was that our other resident purple gtr?
Yah, that was me... That was probably the last time I drove it :cry:
I might take it for a spin tomorrow actually :cheers:
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
