]']i was in my SKY white R32 GTR
with plates JDM-32R
i was in the traffic in the opposite lane and u were in the non conjesting direction :)
Sometime before last weekend, were you going through the roadworks towards Castle Hill at the start of Castle Hill Road (Thompsons Corner) at about 2:00AM?
you know, WRX.
crappy, fwd, understeering thing
Im not sure, I might have got the brand wrong, was it a daewoo? kia?
hehehe!!!
yes i also spotted A-HUGE-xxx on the Anzac bridge, top down, wind in the hair - i think i may have even spotted you running your hand through your hair and glancing in the rear view mirror admiring yourself duncan! is that true?!? :wassup:
that wrx was the WRP10. priced halfway between a wrx and an sti, it has sti springs, sti ecu, sti wheels, sti front strut brace and lots of badges! it went really well. most impressed and more importantly heaps depressed that it reminded me of what a performance car was like to drive! :blast:
round 2:30 was driving near a maroon r33 plate was BENTY on penno rd
then about 3pm behind a r32 GTR gunmetal and no wing on kingsgrove rd
and while on kingrove rd i think i spotted Tommy K filling up at the shell servo
or another black R33 GTR
Benty works here @ ibm, he's parked near me before.
megeer silver 33 on pennant hills rd... boundary rd... new line rd... towards dural last night 9ish
white 33 with a huge rear wing turning right on to new line from castle hill rd this arvo at about 6:30
silver 33 on shepherds drive 6:30ish this arvo... even got a thumbs up :)
I spotted a white R33 series 2 parked on Coonara Avenue as I left the IBM carpark. It was parked, had the drivers window down (white number plates, can't remember plate).
That was me parked outside my mates place. :)
Saw a black GTR pull out of IBM as I left. GTR-**X
um..yeap that would have been after my lil run with the curcuit club boyz through OP
where u driving oppostie direction from me?
should have waved :D
]']um..yeap that would have been after my lil run with the curcuit club boyz through OP
I was about 2 cars behind you - this was before I got my R33 so I was driving the family Camry!
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
