TAY!!!!!! now heres a person i miss spotting.... hows things babe? dont u still owe me dinner? :(.
Thought i saw u at WSID last week... wasnt u tho.... almost as cute but not quite
OMG! you are going to pick up! go for it. put in those hard yards. :P
It seems SAU is being confused with lavalife more and more often. :)
what!!!  are they your plates?  how come you have a gtir as your avatar? i get confused!!!  you really have a r32 gtr?
Yep, they sure are.
I should change my avatar.
I just have the GTR and Soarer now. GTI-R has been sold.
Check my gallery, all will be revealed :P
:slap:
yeah, I kind of wish I hadn't picked such a ghey nick when I joined :P oh well. I'm thinking I might see if I can get it changed. nothing fancy this time. just "Richard". That will ensure it's still valid (unless I change my name...)
ok, now I should stop whoring in the spotted thread... carry on.
OMG! you are going to pick up! go for it. put in those hard yards. :rofl:
It seems SAU is being confused with lavalife more and more often. :rofl:
Heh i'm always getting the 2 mixed up.... last night i spent hours asking women wether 3.5 inch is really better than 3 inch..... they kept giggling at me.
:rofl:
Spotted a White S1 gtst heading towards the gorge from hornsby....
I was going from the gorge towards hornsby.
dont know who it was tho :rofl:
that was me..i gave you a flash and wave. I was very low key today with my glasses and baseball cap on!
I was thinking it may have been but with the hat and shades i couldnt tell.... actually i couldnt tell even without the hat and shades....
Who would have thought.... the day after we both make note to stop each other.... we do.
Can u let me know the detail about yr boot tho. did u do it or did u get it like that. If you did it or got it done can u tell me how/who?
purple- ish 33 gtr strathy. white 33 s2 & red ferrari 360 superdome loading dock. & silver 333 s2 ithink between superdome & p5.
man some sh1t went down in penno this morning while i was waiting 4 a cab. 5 coppa cars within 10 mins. 1 searching the park behind library. bitch didnt indicate. 2 chics got out. & started searching. when i was leaving in the cab a paddywagon came flying down. they were all speeding, no lights.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
