that was me!!!!!! nooooo!!!!!!!!!!!!!!!!!!!! :) i should have tried to chase you down :mad: but yeah... as wilchy said we first thought you were cops, then by the time we realised you were skys i'd already gone past the split road bit, and it was too late to do a u-turn :mad:
you suck andrew!!!! :D
:mad:
spotted a few skylines
silver r33 at dural hungry jacks, white one at the same place, a black R34 gtt near dural (i was turning right)
let me guess - moanie, shonen, and... who's white one? wasn't me... who have you replaced me with!! :cheers::rant:
might have been moanie, shonen and liz (or unknown)
But there's beef at hungry jacks.... hmmm
hehe
that was me!!!!!!  nooooo!!!!!!!!!!!!!!!!!!!! :rant:  i should have tried to chase you down :( but yeah... as wilchy said we first thought you were cops, then by the time we realised you were skys i'd already gone past the split road bit, and it was too late to do a u-turn :)
you suck andrew!!!! :cheers:
:D
Awe. Come on. Don't be like that Moanie. At least I finally spotted you!
You should have chased us down! You suck :D
hahaha... yeah, thats a good point!!! you hesitated in that street.. looked like you were deciding which way to go.. then you turned the other way :cheers: soooo ssaaadddd!!!!!
i was so tired as well!!! and not knowing who you guys were i thought against a chase!!! dammit! i decided wrong!!!!!!! next time! :rant:
4 door r33 on Friday morning, bout 8:40am Warringah Road near Jamison Square. Just saw the back lights.
2 door r32 HCR-032 Warringah Road just near the speed camera bout 2:30pm grey or black one with a few stickers. SAU member I think.
4 door r32 Forestway Shopping Centre Sunday bout 3pm. Green P plates and looked like it had just come from compliance/car yard. Grey.
why do you think its a guy?!?!! pink neons!!! it must be a girl! :(
spotted a weird colour 33 on victoria rd this morning... just after the iron cove bridge... at about 10ish?! anyways.. can't remember the colour.. it may have been an off orange or green or something.. with a black cfb... looked... interesting....
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
