yep BP lights
i only realised it was you after you took off
LMAO the bogan mobile run your car your jk arent you
its a 5L and it still doesnt move i cant wait to get rid of it and get back into my car
hahaha.. i just wanted a run!!! with anyone!!! and you were at those lights.. and you looked like the kind of person who would do a quick run ;) the holden behind me backed off pretty quick.. i was hoping he'd turn off onto kissing pt rd with me!!!! haha.. so that was you with longish hair then!?!??! :(
they are almost my plates i think., but my car is dark blue with a silver front bar.??
I saw the R32 coming out of M2 like a bullet onto Epping Road (heading to city)...took me awhile to catch up!
Also waved/flashed at Sawakita today on Balaclava road - dunno if you recognized me.
i have the car here
im just sorting out all the interior wiring and finishing off the stereo
then its gotta go to the workshop and get all the running gear fitted and all the suspension sorted out and tightened up engine bay detailed wiring hidden etc etc.
then after the SAU show its comming off the road again for some more changes for final battle :cheers:
alright here goes.
last night Spotted Burgundy r33 - zhk-14* about 815 in hornsby and again today at Asquith.
Also last night was a white 33 with black rims at around 930 going past hornsby rsl. Then spotted a r32 on the highway at Waitara (got a wave, can't remember if I waved, sorry if I didn't) which was followed by a 300zx with an SAU sticker.
Around midnight a white 32 with a side mount yellow plate in Berowra.
That is all.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
