Spotted "R34" on the dyno @ Autosalon.  Made 195kw@wheels from memory.
i ran again there on 1 bar after that and only pulled out 216 kw ..i wanted to make it 1.3 bar in my second chance but the dyno guy didn't let me :-(...dunno wat happened there did dyno last weekend gave me 242.5 kw ...huhhh..autostyle r32 gtr broke the record and highest is now 619.9 kw at wheels ...
AHH!!! thats a hell lot of power man! Ur car is powerful too cuz..dont ya worry m8!:rofl:
pfft...thats jealousy right there......  :D
phil....were you in a sky ???
I dont recall seeing one at that intersection...... I was coming back from the nasho run....
Yeah i was on burns road/memorial ave heading towards sunnyholt rd.
saw a black car turn onto sunnyholt from old windsor then saw the stove burner lights, the high GT wing and the thinner number plate "thats DHC right there"
was waiting for my damn lights to turn green so i could catch up to u..
i spotted this number the other day. white 33 s2 ats37l neale ave 11.35
I think it's actually ATD37L .. my car!
Unless there's a ATS37L white series 2 around Cherrybrook. :headspin:
Not many people spot R31s so I'm gonna state that I always see a black R31 Coupe with SLY-031 parked at Chatswood near Penhurst St.
oops. i meant atd. i see u alot hehe. cos i live in cherrybrook
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
