i had an intresting noise last night. i was going down Tudor road into bonnet bay. the "clock" was almost full if you know what i mean and i heard this huge BANG! and thought id really fcuked something.
i slowed down and check a few things and couldnt see anything out of the ordinary, check all looked for stuff leaking.
Im soughta scared to think what it is. it wasnt a bang from hitting some debreee or anything like that. but everything is fine. NFI what it was but if its bad i guess ill find out.........
i get that a bit :P
cept it's more like pops and mild "bangs", just the exhaust backfiring :S
Spotted Duncan's yellow GTR at an undisclosed location :(
Also spotted a silver r33 with a NISMO sticker on the back windscreen and a fusion sticker on the front. I'm sure you saw me and I saw you yesterday aswell closer to my area.
Spotted Duncan's yellow GTR at an undisclosed location :D
hahaha what gave away it was my car? Nath called today and said it was ready to go, so we are GO! for round 6 of the state champs :cheers:
what were you getting done?
777That's only because the Northern Beaches ROCK!
On my way home:
R33 next to an old Commodore on the bridge, left it for dead! R32 and R33 at Chatswood around 7:30pm.
Then my R34 sitting in the garage at home :cheers:
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
