Just saw a r33 gtr ? gts t near ryde on monavale raod with art 97???? number plates and a www.sau sticker on the back, Played in the traffic and gave it a wave. Nice plates, mine are art 40b...... :P
"Spotted gtr_fans mint Aussie GTR at a workshop in sydneys central west, next to a GT-SS track weapon"
Nice t meet up with Ben and yourself, thanks again for the ride, I still can't get over it hence why I'm still awake.lol.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
