the good thing is that i get the red one to learn (fry) the clutch in.
last week in the rain was fun :rolleyes:
sideways in peakhour traffic.... and not on purpose. BUT.... i have gotten better since then :rolleyes:
yea... I kinda feel bad. The red one is just about due for the 100K and they've given it to me for free to drive, so i'm making an effort to drive it smooth and not ride the clutch too much.
I'll be such a granny when i get mine though, even with this one, i wince everytime I go above 5K revs.
It's still fun though :rolleyes:
Also, excuse the whoring. I'm new to this, so i don't know what's acceptable and what's not.
Edited by smasha
Just then, spotted white R33 sedan in Eastern Distributor tunnels going toward Bondi.
I wish there was some (easy) way I could get the sedan rear lights to fit in my coupe body.
Saw a nice silver r33 last night on forestway.. Plates CYAHSV..... Very good plates...
think you might have a front blinker out as your back right hand blinker was going off like a disco!!!!
On windsor road spotted red r34 GTT turning out of RAAF base, a stock looking maroon red r33 gtst and an r33 GTST with nismo sticker on windscreen heading richmond way. Gave him a wave.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
