Saw so many skylines today on the way home from work.
First I saw a bright red GTR going the opposite way on Elizabeth Dr, one of the hottest GTRs I have ever seen!
Then on the hume highway I was behind a silver S2 with number plates bad5?? it turned off somewhere around Casula.
Also at an intersection around liverpool was an orange r32.
Also saw white GTR either yesterday or this morning on the hume highway.
spotted turbos....
spotted a r33 blue with white rims and numbers on the side from wsid
spotted a stocky r33 on pacific highway..
spotted a rather mature woman, grey hair and all in a r32 gtr pulling out of a side street... had a big cooler and stuff on it...
whos mum is that :P
silver r33 giving it a little hit on homebush drive just then, i came up and flew past him, i think he may of got a little suprised LOL....
Edited by mass_iv
Saw a blue 34 GTR plates ACCESS yesty
Beautiful car with some power to boot.
Saw a black R34 GTT with [R34 G1] plates in South Granville @6:10am Tuesday morning.
Saw "NOT ME" gunmetal grey (?) R33 GTR going down James Ruse Dr yesterday afternoon - Souded very nice!
And also saw a nice white R33 GTR (black on white plates i think?) driving north on Pennant Hills Rd near Carlingford - Giving his BOV a workout next to my ear :rolleyes:
Yeah that bright red GTR was probably 'turbos'.. Its definitely the phat'est red 34 I've seen for a while!
He was at CRD at about 2:30 pm yesterday .
Saw a nice looking black r32 parked next to me at work in homebush <_<
Also spotted a nice R34 and red r33 GTR on figtree drive homebush. Parked there every day.... How you beat those parking rangers i'll never know....
Keep an eye out for the white r33!
Theres a few QF people on here E_Lu-SHuN although I'm escaping next week. At least 4 others I can think of, 2 pilots, one in ETOMS. And there is a nice yellow 33 and a gunmetal 32 4 door in the APC carpark but not on the forums I think.
Are you in QFCL?
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
