Spotted a gun-metal grey (i think) R33 in TAMWORTH on Tuesday w00t!!!! Was up there seeing family friends.. soooo happy to see a line!! Went past the import shop aswel, quite a few in there!
Also saw a black R33 and a maroon R33 on the F3 travelling toward sydney on Friday...
YAY!!! :lol:
Finally Spotted....i think i parked somewhere towards the back of the piazza parking....
hahaha.. yeap.. top level :) did you seee meee??
OH!!! and spotted the sexiest blue/silver ceffie parked in my driveway last night.. plates - TAX11Y.. :(
spotted a stupid white mirage infront of me last night getting it's ass out around round-a-bouts with the handbrake....then spotted him going front wheels first into the gutter! :(
the infamous gutter attack eh? i'm sure that technique owned you will.... :)
Spotted! I saw Chris today (evil_weevil) on Somerville Road, Hornsby Heights!
Luckily we were able to pull over and have a chat, it was great to finally run into a fellow SAU'er!
Good looking car Chris, good luck not modifying it :( Hope to see you around again soon!
Spotted a White R33 GTST or GTR (saw it from inside a shop) Near Erina Fair, got a glimpse of a GTR wing with no CF inserts.
Also spotted a SAU member, black R32 with blue plates.. something like GTS25? or something.
Sau sticker (little one) at the lights on Tuggerah Straight.
I was in my R33 on the other side around 2 cars back.. Was gonna honk but horn is sorta on the -_- side.
Edited by br3tt
Richard, (drift king)
Was very nice to meet you mate!!
Thought it was odd seeing another 33 on my road!!:)
Mate, your car looks great and the wheels looks awesome!!
How did the window tinting go? All good I hope!
Haha I'll try and hold out on modding it!!its tough!!
All the best mate and catch up soon!
Cheers,
Chris
OH!!!!!!!!  Also spotted LIZ cruising home from work yesterday!!  she was looking all cute with her dimple and sexy sky :rolleyes:
Hey Moanie
I tried to send you a personal message but would not send this is the only way i can write to you Sorry.
But just a quick question. Did you ever race a silver R32 GTR down James Ruse Drive about 2months ago?
Can you please reply if you did Thanks
Sam
hahaha.. yeap.. top level :(  did you seee meee??
OH!!!  and spotted the sexiest blue/silver ceffie parked in my driveway last night.. plates - TAX11Y.. :rolleyes:
yeah i did, your one has a front mount right?
anyway, when is the next skyline cruise.....hanging to see what you guys get up to in these cruises..
yeap!!! twas meeee!!!!!! :rolleyes:
haha.. not sure.. keep your eye on the events section :( its all fairly tame though :)
GTR32X... pm sent!
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
