has anyone seen a blue GTR R34 with the number plate 34vspec before? also, the number plate if from SA.
how is that car lookin? does anyone know the owner?
i know its John Munro's old car from SA, and its sold to an asian guy in sydney.
Edited by frankxy
Hey, sorry was half asleep and didn't see you till the last moment, you were the white 32 yeah?
Yeah on my way to work, was half asleep as well. you live round this area?
34 VSpec is back in Adelaide to a new owner. The Asian guy in Sydney sold it
The Asian owner did quite a bit of work on it with us and it has since moved on to a new owner
cheers mate for that. i think that guy is overseas now he still tells everyone he owns it coz no one here knows anything about GTRs.
the work done on it was great as i can see. cheers
Was on my way to glenrose to pick up some stuff for work. Quite alot of 32's around that area, and a yellow r34 GTR too.
Yeah that r34 is a vspec. Its NIIIIIIICCCCEEEEEE
Yeh last I heard he was commentating the V8 Supercars in China... haven't heard from him since...
where did you see the car?
yeah, he is still doin that in china plus working for a car magzine and some workshops. because the Chinese car modifying market is still at its very beginning stagte so the opportunity is huge. anyone who knows car can make a lot of money there.
i didnt see his car, its just all over the internet forums in china as the best car of the market. i asked because i didnt believe some things he claimed( he said his car was modded at CRD with GTR 700).
by the sound of it, hes just a rich bastard with a nice car, but hes famous now in china where most ppl have no ideas about cars. certainly his GTR helped him gettin the credit he needed to make money in this market.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
