Saw a white R33 gtst with silver/clear tail lights near Rooty hill RSL last night @ 6pm. Sounded like a rotor :lol:
Also, decided to spot myself this morning on M4 @ 5:30, as no one else has B) :D
:P
i let u go past cos the car looks cool up on that higher far left lane on the iron cove bridge :O
hahaha.. i swear you were in front of me!!! next thing i know i hit iron cove and you're in that lil lane on the left, stuck in trafficses :D hahaha.... :owned: :D
hahaha.. i swear you were in front of me!!!  next thing i know i hit iron cove and you're in that lil lane on the left, stuck in trafficses :D  hahaha.... :owned: ;)
yeah i went up there on purpse
i swung thru 2 lanes to get there
see if u were just behind me in the next lane down, my car would look toit from that angle :)
see if u were just behind me in the next lane down, my car would look toit from that angle ;)
hahahaha.. don't worry.. it did from the angle i had... from approach and side on :D
spotted back 33 GTR (KINGTR) twice, once on sunnyholt rd Parklea, then coming back on quakers parkway.
also gun metal grey or black 33 gtst @ richmond rd/quakers parkway round about.
got a wave! B)
Spotted Tommo in the beastly green Mazda 121, Seven Hills BP... ;)
:lol:
I was thinking to myself "now, should I say hi, this will be really weird coming from someone in a mazda 121"
Oh well, next time you see me down there, i'll be in this :P
Edited by TommO
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
