some one spot me already <_<
I would, but dont know where you live or drive! so cant :P
I spotted a 32 GTR in Hornsby Heights - plates MEL 93H
anyone from here?
looked and sounded horn!
spotted a few in mona vale
in particular a black 33 on a street just off pittwater road in mona vale whilst I was standing next to my car and my friends MX5 who ignored me when i waved as he passed, but on the way BACK he nodded at my friend.. THE GOD DAMN MX5 DRIVER!
PFFFT to you!
:D
LOL it's the weekly spot SATANIC post :(
I personally spotted GTR134 (R34GTR) on George Street; and wait for it TURBOS (R34GTR N1Spec) - the 1000hp Skyline!
Had quite an extensive chat, made a small proposal and watched him do a 10k launch right outside Harry's Cafe :(
I'm in heaven...
Oh correction, make that 1150hp +
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
