spotted Eathan again (rancix) near the gorge - snob !!kidding mate - i was in a mates car going to driving range thats why you didnt see me :O
ohhh sorry, if ya wave big enough from the car i mite wave back just to be nice even though i have no idea who it is :P
spoted wink today at castlehill around 6:30.. was stoped at the main lights on oldnorthen road b4 ya go past the piazza (sp?), waved, but he wasnt looking.... well i think it was wink, hahaha
ohhh sorry, if ya wave big enough from the car i mite wave back just to be nice even though i have no idea who it is :)
I was in Chatswood at that time so no not me. :no:
Talked to mass on the way to Chats though. :(
Spotted so many nice cars on the way to work today...
As soon as I got on the M5 there was a maroon R33 with two wings so I got behind them and followed all the way to Liverpool exit.
Then on the hume highway a dark R32 came up beside me and the number plate was A??33R. On elizabeth drive saw a bright yellow R34.
Also spotted two 300zx on hume highway and wallgrove road.
Tues night.. at about 10.20pm? saw a goldish.. 33 on the m5 heading towards mascot.. plates anu - something..
Last night
spotted a gunmetal grey 32 gtr last night on the m5 heading towards camberra way.. plates where like ate - something? some old man driving it.. hehe.. that was at like 6.55pm?
and saw a white 33 with a black or cf bonnet with some airbrushing on the side of the car on railway pde glenfield at 7pm.. didnt catch the plates..
I was in Chatswood at that time so no not me. :D
Talked to mass on the way to Chats though. :D
My friend on another forum thought you were me... and tried to tell me I was in chats wood...i kept telling her it wasnt me.... must have been you
No one spotted my R32 yesterday?
Even went through the city
You all suck :D
I DID!!! I SAW IT!! Was just about to post up...
It was on a towwy... I was in the landsdown upstairs pub eating food at around 4:30.
I looked at the car and said... hmm that GTR looks familiar
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
