spotted-
eurospecs' mum's car at my house last night...
wont bother making two posts about spotting her, as i know she'll be back tonight. maybe tomorrow night as well, if she gets time off work.
let me know eurospec, or i'll make other plans :D
wtf
what a lying bitch! she told me she was sick... u're dead v_twin! :thumbsup:
Did you see an L plater? That was me
haha yes I did, so it was before dropping me home. I thought it was a bit strange seeing a l plater out heaps late
should have recognised you from your picture :thumbsup:
you looked a little freaked out when we drove past though
or you looked like you wanted to check out the car, but you wanted to watch the road lol
Guest Xinhua
hehe you saw my face? I was next to my father coming home from cinemas. giving him a lecture about skylines, then there was miss turbo and i was like wait a sec, i know that car..
lol it was at the part where the road curves like shit, i was checking out the car and then the road came along :(
Spotted Mass_iv at Northern Beaches Performance last week getting some work done...
Spotted Lingeringsoul at Northern Beaches Performance yesterday getting a FMIC, BOV and SAFC done...
Spotted ZIL32A at Northern Beaches Performance yesterday getting some polishing work done...
Spotted SATANIC at Northern Beaches Performance getting stripped down for more work~
All looking good boys!
spotted tolga on pacific hwy :) i love the purple.. hahaha.. sexually frustrated purple :(
hey.. the car gets plenty of loving and is not frustrated at all.
Gave it some loving on Sunday. washed it good!!!
The paint even smells nice..
gotta love zymol car polish.. smells like coconuts!!!
Car is at NBP stripped apart for more goodies...
I'll send you some pics later, got to get the other mechanicals sorted first. Wouldn't want to have my new dash scratched now would I?
Spotted some stuff over the weekend.
"...-641" somewhere .. cant remember :ermm:
ATT 7ID orange 32.. Nice paint and kit but it was lookin like it was gettin stripped in a garage, I won't say where incase it's legit cos I don't want to advertise it :D
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
