I also spotted a Massiv lookalike white R33 on Epping Road near Mac Uni. I swear it had the same front bar as yours mate but the guy inside didn't look like you (well he had glasses and I think he was Asian).
:thumbsup:
nah man cant be i havent seen one like mine around that area :(
iv only seen one car with my front bar and the guy wasnt asian... and i saw it last week!!!
stupid copies, wanna be like me hrmmmph :dry:
From another forum :D
To the person who owns a white Skyline with the NSW plates of HUH-000, your stupid goddamn xenon/hid/whatever headlights are TOO GODDAMN BRIGHT. Thank f**k that you were speeding, or I would've had to put up with that shit blinding me as long as you were following me for.
spotted a white r33 with gtr wing, on old northern road i think, its near stockland mall at baulkham hills at 3.15pm. car was up on the gutter and the back drivers rim was twisted and bent under the car.
Drifting maybe???
Spotted a silver R33 GT-R in my street in Toongabbie all of 2mins ago, seems to be here quite often. I've grown Skyline-sensitive ears over the years, and know when it's here even when I don't see it arriving.
Not sure of the number plates, even with glasses my long-distance vision is fuXored. Mind you, it's only about 25m away.
I've been either seeing (from a distance) or hearing this car just about every weekday now for about 3 weeks, usually around 5.45pm. Still wondering who it is, because by the time I get out the door to see it, it's gone...
Hey man wat forum is that from??
My friends car is HUH.000...im getting the same 12000K HID as him.....they r so bright it can light up a whole carpark at night
Edited by skyline17
From http://forums.overclockers.com.au (you need to register to enter the forums).
I suggest your friend get his headlights properly aimed/aligned ASAP.
also a big WELL DONE to AWK98J (r34gt-t) who tailgated a 4wd on mona vale road for a bit then proceeded to overtake him doing in excess of 100km/h in the emergency lane.
That was so not cool.
spotted a white 33 gtst - green p plater in leighton place hornsby
both waved :D
and a maroon 33gtst with bodykit, wingless - both gave waves :) in hornsby again
hallo if your here!
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
