I spotted a nice Red R34 coupe with clear tailights and a nismo kit on sunday night...while i was filling up petrol at the quix just off northern road in penrith.. Said hi to the guy but i was on my way home need to get some sleep so i could be up for the cup finals...so i didn't get time to talk to him much...
Edited by Pac
Spotted a purple? or Pink skyline? with done up interior along liverpool street Saturday nite. (Though I could be mistaken)
Then saw alot of skylines around Cabramatta on Sunday.
My pink skyline? :)
spotted SMASHAAAAAAAAAAAAAAAAAAAAAAA on teh old pac today!
lol. Thought it was you, only saw the handwave so i wasn't sure. :thumbsup:
There was a cop just next to the truckstop. He would've clocked me @ 79 :wacko:
Lucky he wasn't near any of the bends
Edited by smasha
spotted alien, a white 33 gtst, black 32 gtst, gunmetal 32gtr and a few more in the city tonight!
was that u on parramatta rd on friday? ... i was in the white r33... shopping list on the side :thumbsup:.. gave u a nod?
spotted black r32gtr today... parramatta rd strahfield at the lights.. numberplate maybe gtr32r maybe??..
think i spoted Liz waving to me at hornsby yesterday arvo around 5:30 or so. i waved back, dont know if she saw me.
:woot: I saw you wave back.... took your time though!
I also spotted you last night.. was driving behind you past the police station at hornsby until you turned off! No wave though :banana:
lol. Thought it was you, only saw the handwave so i wasn't sure. :)
There was a cop just next to the truckstop. He would've clocked me @ 79 :rofl:
yeah i saw him on the way back! lucky!
I spotted 2 33 GTSts this morning on the pacific highway
I was heading south, they were going north
a grey one and a white one - didnt see me though
and spotted a grey 32 GTR last night, Beecroft road to Penno Road, I gave a toot - followed you for a bit!
Saw a few lines over the weekend. Amanda's R32 in campbelltown heading up to macarthur, number plate AWL-15F.
A tiger gold R33 all riced up with wing the same time as above.
On Sunday a maroon R33 heading out of campbelltown towards appin, thrashing it being a bit of a hero. Car sounded a bit sick but probably just the exhaust.
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
