That wasnt SECRT - The top secret built GTR was it? I hope it wasnt, cos that thing is FAR from rice! >_<
I dont remember it having those plates. And ignore me anyway, i call anything rice with a wing like that and which looks hot. Probably cos my car is more like a damaged battletank. :)
I know the feeling Vic,
took it out last wed night and new clutch seems to be stuffed...or not fitted properly
so back in the garage she goes.
Time for LS1 power...again.
pm me details chris! I had a few problems, might be able to shine some light on things for you!
Spotted on bernera rd casula, bayside blue R32 GTR with number plates HOT-53X, looks just like Mansoors car!. Followed him all the way down Camden Valley way til my turn off at Currans Hill, is he on here?? seemed abit of a noob though, tried to race me!! sif.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
