wouldnt the kombi's be going to nimbin???
:miner:
spotted a 4 door 33 at Asquith BP with a boostbitz............sticker.....
so did i was it at 2ish coz i was there filling up my car at the same time prob didn't see me as i was hidding in the middle
spotted dark green or blue 33 with chromies at the end of the F3 friday morning.
also spotted white 33 on pacific hwy wahroongah about 5 mins after that, think i got a wave back but not sure?!?.
Spotted BEC070 on Thurs (?) arvo at Pac Hwy West Gos...
You didn't see me!
spotted Abo Bob this morning on the near the pacific highway
and gengis on pennant hills rd at oatlands :miner: (i noticed the hit on your front bar thats how i knew it was you)
LoL i spotted you too hiya - Looking clean and mean there
I was running around getting quotes all day hehe
Just want to add i saw a silver r33 on victoria road whetherill park driving past Del Mar (I think) smash repair and a couple of black 32s at xtreme bodykit at Warwick farm
Edited by Gengis
I saw the most god ugly R33 GTS-t on Friday night on Abbott Rd just before the start of the M2.
DR4GON... Green R33 GTS-t S1 with spinning chrome wheels that look like they hadn't bee nwashed since they were sold new....
For crimes against Skylines....
i've seen this car before..
this bloke has no taste what so ever.
That might have been mr_ed32 what colour is youre 32? and are you around the eastern subs?
yeah im in the eastern suburbs and my 32 is white
they were in a white 32 corrine! do you have white rims on your 32 and yellow plates? if so i see you all the time, city everywhere!!!!!!
nah silver nissan stockies with yellow number plates. and not really in the city much, must be another 32
hahahahahahaha
spotted a r33gtr plates MIK82* penno rd carlingford... about 5pm or so.
spotted a big bunch of VW Combi's all in a line following each other on Newline Rd this morning.
Should we be worried?
I have a feeling there's gonna be a mass-suicide happening today....
There's a VW meet on this weekend at Nambucca Heads on the north coast - no doubt they were all heading up there...very slowly :)
My best mate headed up there today too, he goes almost every event and has asked me numerous times to come along. He's driving his friend's car up, his wife is in tow with their sons in their 01 WRX, and the friend (who works for Subaru) is driving a current STi up, just to keep the whole flat-four theme going. I really should go next time, would be a good chance to get away from Sydney.
there sure was a show up at nambucca heads!! we bumped into a fair few convoys on the way up!! saw some hot looking vw roadsters as well... i'll have one!!! :D some of those combis were also in immaculate condition!!! :P
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
